Dual Chamber Enclosure Wiring Help
awehlage
Alright members, be gentle as this is my first post.
Recently received (2) SoundQubed HDS312's D4. I am going to wire them in parallel/parallel down to a 1 ohm load. I have the diagram from the12volt.com No questions there.
My questions are am I stuck having most of the wiring outside of the enclosure because it is a dual chamber and I can't keep the speaker wiring internal? Is it recommended to use the terminals on the enclosure or should I install different hardware?
Any help would be greatly appreciated whether it is a simple reply or link to a resource! Thanks!!
Here is what you can do, have 4 terminal bolts to each side of the chamber so 8 bolts in total. Wire each coil's + and - to the terminals and then you can do the parallel wiring from outside the box. Easy access to subwoofer wiring without taking the subs out of the box.
http://i236.photobucket.com/albums/ff209/cole4pres/0252.jpg
Thanks Jeffdachef, this is awesome! Appreciate your help.
Any certain size bolt to use? Stainless steel okay?
Should I just not touch the terminal cups on the outside of the enclosure?
awehlage
awehlage
Kimberly, WI
awehlage
