Dual Battery or Batcap Powerpack?
extra battery, been down the batcap road, never going back...
Batcap Pros / Cons?
I have a load of spacing issues for the sub box and an extra battery, given that I want to continue using my truck as a true working truck (i.e. cargo bed and rear seat).
if you are tight on space get a batcap 800 they are small and i think with a big battery upfront like a batcap2k or something big upfront big 3 and a batcap 800 in the back u will be fine
what size alt do you have
i am running a zx1500 and zx850.4 and only have a 130amp alt stock, no big 3, duralast gold upfront and stinger spv70 in the back with a run of 1/0 pos and ground from the front the amp voltage only drops to around 12.2 or so the battery is around 12.5-12.7 in the back the front stays 13 or above at idle full tilt
the extra batteries worked better for my application. i had the room for extra batteries and the batcaps did not have enough reserve vs the odyssey 2150. with the batcaps i still had the same voltage spikes but with the odysseys i never dropped below 14 volts at full tilt with a 40.1
Which Batcaps were you running?
Omega3dog
Que-rious
Omega3dog
Washington D.C
Thorracing01
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
