BAttitude7689
is this possible (2) amps running off (1) 8 gauge wire. I have my one amp as i explained which is 2-channel 400 total watts running (2) 10's i wanted to add another amp which is 4-channel 300 watts total to run my (4) door speakers. 300watts divided by 4 is 75watts per speaker and my speakers are 150watts max. How can i go about hooking up that second amp withouth running another amp wire from my battery to the trunk am i capable of spliting that wire to use both amps...i have read around you can use a Distributor Block but the orginal power wire is 8 gauge is it safe to use the Distributor Block with 8 gauge wire. I also read I can use that 8 gauge wire run it into the Distributor Block and then use 4 gauge wire to from the block to each amp. Whats my best way going about this
