Dual amplifier kit?
Durry
what dual amplifier kit would you guys recommend, or which components to install 2 amp would you recommend me.
please list the name of dual amplifier kit
or separates components that i would need to buy in order to install 2 amplifiers
the amplifiers are Polk Audio 330.2
i already got a rockford RFK4X complete amp kit, what else do i need to complete the second amplifier installation..?
sounds like you need a single 4 ga amp kit to go along with the Rockford kit...That would be the best with plenty of room for the amps on the power wires...you might also distribute to 2 8 GA wires close to the amps from the 4 gauge kit you have??? What size wire fits in the amps?
Sorry, I missed the part in the OP, when you mentioned you already had a 4 gauge kit. Go to KnuKonceptz and buy however many feet of 1/0 you need to reach from the battery to the trunk(or wherever the amps are mounted). Either option will work, they're OFC, here, or they're CCA, here. Pick up a distrobution block that has at least one 1/0 input and at least two 4ga. outputs, like this one. Shop around for the distro block as they may be found cheaper (i.e. our classifieds section), I'd recommend staying with a fused distro block like the one I linked though. Or you can use the existing fuse/holder you have, pick up a second and fuse each 4ga. strand coming from the distro block separately. You won't find much better wire for the money unless you find someone in the classifieds selling a leftover strand that's long enough. Even if you buy new, you'll spend under $100
man, If your going with 1/0 cable, and wanna save a buck, go to a welding store and get some welding cable. I dont care what anyone on this forum says, its grand on so many levels.
Durry
Durry
Puerto Rico
Durry
