dual alternator setup on a honda?
yep actually Ive talked to alot of alt places and they say all the honda stock alts are one wires really just have 2 extra wires fro some reason.I bought a 215 amp from db linc alternators and i havent installed it yet.How did your big 3 turn out did it help any
This is the eld from the fuse box its on the secondary main fuse link
840
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
833
941
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
loudREcivic
loudREcivic
alpena,michigan
Buck
    May 16, 2024
    May 16, 2024
