Hi,
for those of you that didnt see my other post im working on putting together a sub box for 2 Alpine SWR-1242Di've played around with the numbersand i have come up with what i believe will work but im not sure. it is 4ft^3 tunned at 32hz and here are all the dimensions (just once you open it maximize the window then zoom in and you should be able to see all the numbers. all the numbers include the MDF width so the first numbers are NET width/depth/height)
http://img47.imageshack.us/img47/9633/boxplansgm1.jpg
again im looking for all your comments/suggestions this is my first time putting together a system never mind putting the box together so any suggestions you guys could give would be much appreciated
Also i always planned on putting carpeting on the sub box but i just thought of something, what the heck does the carpeting do? i guess it must dampen the sound but other than that does it do anything else and should i or shouldnt i get is based on my setup? what would you do? adn what type of carpet should i use?
~Thanks
~Thanks
