dual 2ohm sub...
well actually one question that may not mean anything but with the audioque subs its not spring voice coils just wires...and the picture i see for wiring dual 2ohms is you put the pos. to the pos. and neg to neg. but you then run a wire from one pos and from one neg to the amp. like one from each voice coil. do you get what im saying? so would it matter if i just took the wires and twisted them together and used a wire connector to connect a new wire and run that directly to the amp? like twist the posatives together and negatives together then just run it to the amp? or does it have to be one from each voice coil? please pm me the answer
wire it just like this.
the answer to your second question is no, it wouldnt matter how you connect the two voice coils, whether you jump with with a wire or twist the seperate wires together as long as you keep the - to - and + to +
michaellane
michaellane
tx
jeepintn
