Dual 2ohm Speaker On A 2 Channel Amp
well here is the thing. Amplifiers dont have a certainmaximum ohm load they can play at, so the resistance the amp is seeing is not making it shut off.
Actually, I just thought of this. If you are wiring each VC to a channel by mistake, then it may be the resistance because each channel is seeing 2ohms, and your amplifier may not be 2ohm stable. What you would need to do in that situation is wire the sub in series and be sure to bridge the two channels, if your amp has that feature. Otherwise, wiring in parallel would do nothing but drop the impeadance to 1ohm.
i have it wire in 2ohm load amp still cutoff. lanzar vibe 268 //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
DVC 2ohm sub.
Wiring options- 4 or 1ohm
You cannot wire it for a 2ohm mono load, stop screwing around and wire it in series.
Like this-
DVC 2ohm sub.Wiring options- 4 or 1ohm
Like this-
i have 2 dual 2ohm speaker //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Well maybe you should have said that then, instead of dvc speaker //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Either way, if it is going into protect with them wired in series then that means the impeadance is TOO low, wiring them in parallel will only drop the R even more, so it wont help you. Wire each in series and then wire each to a channel. Your amp should be able to run each channel at 4ohms.
Also, are you not american/native english speaker or do you just not know how to talk?
dron178
dron178
OKC,Ok
RandyJ
