dual 15s
I don't follow5 cubes after displacement?
---------- Post added at 10:52 AM ---------- Previous post was at 10:51 AM ----------
Nevermind, I get what you're saying
for example in a 2 cu ft shared chamber for 2 subwoofers, each sub will see more than half of the chamber. they should see about 1.3 a piece. or something along those lines.
If you set the box up the same as the 18 on the same power your only going to gain maybe 2 dbs. When you double the power and can keep the voltage up you might gain 2.5 more. Thats going from a 144 to a 149. Maybe less, you know how this stuff works. I say Wall IT!
I have my port on driver side too, but have been wanting to try passenger side. Maybe with the port further away and not right behind my head it might sound better
it will sound better but it wont meter as high and you will be in the hot seat all of the time... idk about you but I like the womenz to be in the hot seat... //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
You lost me.. Speaking of seats, I think im going to pull out my passenger seet to add a ton of D3100s for a 10k upgrade. People getting demos can sit on the battery rack
this is pretty much the final design, each sub sees 3.38 cu ft, tuned to 33.88hz... hoping for a 48 outlaw on music, on 1 saz3500, and a 150 on two saz3500s.. I choked them off on volume a little bit to increase the power handling, I know many of you said to do a single chamber but I havent had good luck with the single chamber designs that I have made... Idk what my woofers fs is going to be but they should be within the 32-38hz range, so tuning a few hz below or above them wont hurt much at all. comments??
RangerDangerV2
RangerDangerV2
st cloud MN
RangerDangerV2
