dual 15" IDQ IB help please !
mattmcss
Shake that laffy taffy
Alrite heres the deal, I'm trying to run these sucka's IB in my trunk, my car is a 2000 grand prix, heres a shot of the part that comes down, that panel there also pulls down to be open the the trunk, which is what the front piece on my model will match up to
In this picture, that open area will match around where the middle part of the backseat pulls down
This shows where the subs will be mounted, magnet out , I'm just wondering if there would be any disadvantages to this setup
That model will have a very large peak at a high bass frequency, say somewhere between 150-200hz , you'll need a steep x-over slope (18-24db oct) to make sure you won't hear it, other than that it should work fine.
well I can do 24db/per on my amp, i'd probably cross em at like 70ish hz, if i can smooth out the area between the subs and the front edge, will that help ?
Yea I did a quick rough model and the peak is around 10db at 180hz, so with a 24db slope starting at 70hz the peak will be ~14db down, that combined with the cabin gain you'll get at the lower frequencies should make it more or less unnoticable.
Make the large chamber the 15's fire into as small a volume as possible, the smaller it is the higher in frequency the peak will be and the more it will be rolled off by the x-over. The smaller section acts as a port, make it as large(surface area) and as short as you can, both will increase the frequency of the peak.
mattmcss
mattmcss
Twin Cities
mattmcss
michigan born
    May 14, 2026
michigan born
    May 14, 2026
