Dual 12 inch Audiopipe Ts-Pr's With Lightning Audio amp. Need help.
Audiopipe TS-PR12BL TS-PR Series 12" 750 Watt Blue Subwoofer, 750 Watts MAX Power, 375 Watts RMS Power, Frequency Response 22Hz - 100KHz, Sensitivity 95dB, Rubber Surround, Blue One Piece Metal Cone, Candy Blue Painted Steel Basket, 2" 4 Ohms 4-Layer Dual Voice Coil, Conex Spider, 60 oz. Magnet. I need a way to wire each sub to a 4 ohm load and i have no idea where to start.
If it is a Dual 4 ohm subwoofer as stated in that description, EACH subwoofer can only go to either 2 or 8.. Both subwoofers combined however, can achieve a 4 ohm load.. What exactly do you need? What amp are you trying to use?
Sigh...
552
707
westwest9994
westwest9994
Bolivar Missouri
Decebal
    Jun 10, 2024
