Dual 10" Fiberglass Enclosure
jake21
Lifted > Lowered
Hello CA, hows it going. Well long story short, my friends are eating away at me ordering sub boxes from me left and right. Here is my most recent one i am working on for my buddies truck. It will hold either 2 older Kenwood 10s or some of the new Kicker 10s. Enjoy!
Frame and port all nailed/glued together
Flush mount rings added, just ready for some fabric which i will be getting tommorow
Test fitting some tens
let me know what ya think!
why are you using particle board //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
stuff soaks up water like no tomorrow //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Question: How in the world is the port length calculated on a fiberglass enclosure?
I would imagine its pretty easy to be off on tuning frequency when you don't have any specific dimensions from which to calculate the enclosure volume.
Fill the enclosure with small beads of foam, or something like that.
Pour the beads into a container of known volume.
Voila, there's your volume.
Unless he is using it in a boat, I think he will be alright, lol!
i live in a small town, 1200 people, this is all they have at the lumber store...
guesstimate and then double check with the method quoted bellow VVV
Fill the enclosure with small beads of foam, or something like that. Pour the beads into a container of known volume.
yup
Very well said, i think that gets the point across //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Uhh....Add bass to a trunk and voila you have a leaky trunk.I have seen it many times,espeially in trunks.They leak, the box soaks up the water and its toast.
Partical board is just a way to cut cost.Not my thing but if its all you can get and no one complains who cares.
But yes Req was right its like a big sponge,not as compacted as MDF.
Uhh....Add bass to a trunk and voila you have a leaky trunk.I have seen it many times,espeially in trunks.They leak, the box soaks up the water and its toast.Partical board is just a way to cut cost.Not my thing but if its all you can get and no one complains who cares.
yes that is true, im also not trying to argue, but this is going in a TRUCK not a TRUNK
The last box I built was out of particle board, and it held up just fine for over 3 years in the trunk of my car. Granted it wasn't a power house 2 12" Infinity subs off 300w each so it wasn't gonna bust the trunk apart. I am wondering what will happen when the resin hits it though seeing it soaks up water. Either way the wood working for the box sure does look good though. Looking forward to the next stages of the build.
^^ you had to spoil everyones fun of thinking that it is going to soak up water:(
Well someone is likely to come in here in the future and argue his 2 cents so lets see what happens... Maybe i will fill the enclosure with water to see if the makes the bass hit harder................
//content.invisioncic.com/y282845/emoticons/slap.gif.87520e8ca8e90076ac30e777c0de5331.gif
839
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
832
940
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
jake21
Lifted > Lowered
jake21
Bozeman, MT
jake21
    May 16, 2024
    May 16, 2024
