Downshifting question.
Intrepid Bass
Dade County
I'm wanting to clear some things up on down shifting. While driving on streets and highways, Is it ok to put it in neutral and use the brakes to come to a stop? The other thing is on the highway when passing someone when you're in say 5th gear and you want to pass you slow down to a certain RPM, downshift, merge in the next lane then speed up back up to 5th. I was watching this video.
http://youtube.com/watch?v=roaEXp1Mb1g
its ok to go into in neutral but downshifting will help reduce the wear on your brakes. When i pass someone say im in 5th crusing at say 50mph in my car i usually "rev match" meaning i will first push the clutch in and rev higher before dropping into a lower gear. if you just drop to a lower gear and release the clutch then it causes alot of wear and tear on the ****** and jerks the crap out of you and the car.
you could modulate the clutch:fyi:
however how most people drive, yes it will jerk you
and giving a little gas to bring the transmission up to synchronization is a good idea
this is how i usually do it though. crusing behind some slow poke in 5th gear doing 50, i push the clutch in drop to 4th romp the gas and let the clutch go. i know my car and i know at what speeds in what gears turn what rpm. when i do this its smooth as butter!
i never (rev match) if im going down the road in 5th and want to go to fourth i just put it in fourth and slowly let out the clutch while starting to accelerate.
but you know your car....takes some people years/decades to get to that point:laugh:
and if I downshift with my petal on the floor I would end up in a ditch
its ok to do that but the more you easily release the clutch like that the faster you wear the clutch out. the less time you spend on the clutch pedal the longer your clutch will last.
Intrepid Bass
Dade County
Intrepid Bass
FL
Steven206Seattl
