double or single
rap hip hop and so on, my concern is that george at atomic will make them for daily but the 18 will be at its full potential, oh well, i guess u guyshave a point, when its down the road, i can always put another 5000.1 in so one to each
what kinda music,
but regardless of above question I would myself go with the 2 15's
Gl to ya
How would the type of music affect his question, or its answer, in any way?
To the OP, would you rather have one sub working as hard as it can to produce a given output, or would you rather have two subs only having to work at half their potential to get that output level? Which, do you think, would output less distortion? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That answers your question, but does not fit your situation. The 18 has more cone area, it would not have to work twice as hard to match the output level of the two 15's.
The two 15's, generally speaking, would be better... when comparing like model subs. Usually abit more cone area, plus two motors to soak up the input power and dissipate the subsequent heat. But it will also cost more coin.
i just like single sub setups, and the 18 stroker that i was runnig got pretty **** loud, maybe louder than my SX 12's that i ran. Your situation is diffrent cause your wanting to run the 15's. Plus the 18 will be pushed to a great potential so all you need is a good box design
i would rather run one 18 at its full potential, then run two 15's half ***. i feel that you will be much more satisfied with the 18 but thats me
Half ***? You do realize, as I pointed out above, the LESS a sub must work to produce a given output, the less distortion it will create in the process, right?
Your reasoning makes zero sense. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i didnt even read that. sorry man, with the line there, i figured it was your sig so i didnt even pay attention to it
LMAO... I actually totally understand and can relate to that. No problemo. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
MikeNeufeld
MikeNeufeld
VanCity
helotaxi
