Does your electrical see impedance rise
Based
Ok so say your amp does 1500@1ohm and 1000@2ohm. And for example, impedance rise puts it at 2 ohms at 40hz and you are at 14v DC when playing that frequency. Does that mean your wire/alternator only sees 1000w/14v = 71.4 amps? Or does it always see nominal?
Yes you are correctIf you rise to 8ohms you will be making very little power but that means your electrical will be at 14.x volts and getting the most it can give
Ok yeah that's what I thought.
So really for a CAB 1600 I just need 4 gauge wire not 1/0. 1600/14.4 is 111 and 1600/12.6 is 126.9 amps. I'm gonna rise to about 2 or maybe 3 ohms so I'll only be making like 1000-1200 watts on most frequencies so that's only around 90-100 amps.
Don't undersize your wire
Just because you have 2x rise at one frequency you could have very little rise at another frequency
If you don't have the wire yet get 1/0 it's not that much more and there are benefits
You are also not factoring in efficiencyDivide your numbers by .8 best case and you quickly get up to 140 amps
Ah ok yeah I forgot about that. Well I already have about 20 feet of sky high 1/0 from my last build. I will use that then. My wire is only about 10 feet long. My car is small.
Based
Based
Louisiana
Based
BP1Fanatic
BP1Fanatic
