Does this mean that is the RMS?
How bad are they? This is like 100bucks shipped... So I might buy it.. Should I not? I don't have very much money and need something that will do better then the amp I currently have.
I was scammed big time on this amp I have because they knew I have 0 familiority with anything CA related.
with 2 fuses at 40A it seems perfectly realistic to expect 350x2 or 700x1 bridged at 4. The question, considering the $100 price tag is will it last.
You might check out the eclipse xa1200 at sonicelectronix. 600w at 2 ohms, modern amp technology, high quality, high reliability -- not sure why they're selling them so cheap (130 shipped).
http://www.ugotadeal.com/advanced_se...0i5e84&x=6&y=5
CRUNCH P1400.2 2CH 4OHM 1400W CAR AMPLIFIER P-1400.2
2 Channel - 4ohm
1400 Watts x 1 ch @ 4 Ohms
700 watts x 2 ch @ 2 Ohms
350 watts x 2 ch @ 4 ohms
Bridgeable amplifier
MOSFET outputs
PWM digital power supply
High level inputs for OEM Radios
Fully Adjustable Crossovers
SEPP A/B Class Amplifier Designs
All 2-Channel and 4-Channel Feature Bridgeable Designs
CRUNCH Illuminated Logo
Rugged MOSFET Pulse Width Modulation Power Supply for Instant Maxx Power Output
1-Ohm Capable A/B Class Mono Block Amps
2-Ohm Capable A/B Class 2/4/5-Channel Amps
4-Channel Amps Configure to 3-Channel Right and Left and Sub Mode Amp Protection with System Diagnostics LED’s to Protect Against:
Current / Amperage Overload
Short Circuits
Thermal Overload
DC Offset
Hi-Level Speaker Lead Inputs on 2/4-Channel Amps
Silver Preamp Level RCA Inputs
Daisy-Chain Line Outputs (All Except 5-Channel)
Mono Blocks Include a Remote Bass Control
Oversized Speaker Terminals
Powered by Maxxsonics Technology
Versa Cross™ Electronic Crossover offers:
High-Pass Versa Cross X-Over Adjustment 60Hz to 1.2kHz (Mono Block Not Included)
Low-Pass Versa Cross X-Over Adjustment 30Hz to 250Hz
Stereo / Mono Amplifier Mode Switch
Speaker Lead High-Level Inputs for Receiver such as OEM Radios Lacking Preamp Outputs
Configuration Switch for Changing Channel Operation When Using Bridging Function
ArcFault
ArcFault
Canada
n2audio
