Does Port Diameter Matter?
So I might as well go with a single 2" diameter port that's 1.5" long, to tune to 35hz? That just doesn't seem right for some reason, I always see people use bigger ports. 2.35 net internal volume, I used this calculator:
http://www.the12volt.com/caraudio/boxcalcs.asp
No. What is the size of your box, after speaker displacement. What speaker are you running, What kind of power will you be running.
I'm building two indentical boxes, one on each side of the trunk. After displacement, the volume is 2.35 ft^3 each box. I haven't built the boxes yet, but that's the plan. External dimensions are going to be 13x13x35. I'm running 3 MTX Terminator 8" subs in each box, and they're going to get around 100w RMS each.
How would I make it?
With wood??????????????????????????????????
Ok your going to use one side of the box as a side of the port. Just build the port on the side. Have it bend in to the box at the corner. And keep the port area constant all the way threw.
Jonahdude
Jonahdude
Florissant, MO
DFW40
