Does more power make a speaker perform better?
Say that i swapped my set of components(see sig) that are 50-75 watt rms running on a 50 watt rms x 4 amp with a set of HAT imagine or clarus components that are around 100 watts rms. Would they perform to the best of their ability, but just not as loud as they could be? this is just something i was curious about, i wouldnt be doin anything like this for a long time, but curious if this would make sense. What do u guys think? Would i notice a large difference in sq and/or midbass? ive never heard any real systems, and nothing that sounds better than my speakers, so i dont even know what better sq would be like, mine sound pretty good to me, but car audio is my hobby so i want to keep moving forward
In my experience, the Imagine speakers sound good with 50-60watts of power when running in passive mode. If you run them active or in bi-amp mode, then the woofer could take advantage of a bit more power. For HAT Clarus, I would say they can take a bit more power because the woofers have higher excursion capability and the tweeters are attenuated with a passive crossover.
^^ Nothing like some clipping to wake the speakers up in the morning LOL. All I will say is it is better to overpower your speakers with a clean signal then it is to clip them to death with dirty lower power.
This. Mids/highs really seem to wake up when given more power; as long as said power is clean. Sending any speaker a dirty signal for the sole purpose of trying to give them more will do nothing but hurt SQ and shorten the life of the speakers and potentially amplifier(s).
Personally I just changed my system around.
I have a 4 channel MB Quart amp that does 100 per channel
I was running 100 to each of my High end Old School Q Series MB Quart Components in the front in fully deadened doors.
I was running the other 2 channels to a 10 JL Sub
I added a sub amp (and a pair of 12's) and bridged the 4 channel down to 2 channels.
I was very surprised at how much better the front components sounded with more power
Hard to describe but so noticeably better that my GF (who does not know a lot obout good sound) told me how much better the front speakers sounded.
That is just my experience.
Personally I just changed my system around.I have a 4 channel MB Quart amp that does 100 per channel
I see this happen all the time. Moar POWAR! Tim the Toolman had it right all this time...
Hahaha thanks guys for your info and personal experiences, in the future if I get a lot of money saved up, I might upgrade he fronts to he imagine components, I love this forum there's so much info floating around, another question for y'all why do ppl have more speakers, is it just for more volume? If I upgraded in the future, would I want to run my set of pioneers in the front with the imagines?
Keep_Hope_alive,
I agree with much of what you said, but there are a few key points that I'd like to discuss.... all in good fun (learning experience for others) //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
the difference between 50W and 100W is, at most, 3dB of output. there aren't many speakers that could actually handle that much power anyway...
Every double in power is 3db, however I definitely can tell the difference between half-volume and near full volume. This theoretical db limits to a human's perception is just that......everyone has different perception of volume levels. This also comes down to about 70-80% install. Poorly installed speakers, large cabins, or too much sound deadening can really kill a high powered set of speakers.
My front speakers in my bus are wired to 2 ohms stereo, about ~125WRMS. The speakers definitely will NOT push me out of my van at near full volume. My system in my BMW is 50W per channel, at most, and definitely will push me out of the car at near full volume.
The "come alive" point VW mentions above is probably around 3-5W. most people, regardless of what equipment they have, rarely give their speakers more than 10W. around 10W of output power, you are around 100dBA of output (assuming typical sensitivities) - which is loud for anyone and not a suitable level to hold a conversation.
Depending on installation and speaker sensitivity. A speaker with a poor 79db sensitivity (1W @ 1M) might be pushing 90db while the one up around 91DB might be pushing 105db or higher, at the same power.
I still say, there are a lot of speakers, and installations especially that require higher power on X car, than it will require on Y car. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I run two sets of mids and tweets to help keep up with the substage. I like to actually hear my music at full tilt rather then having the subs just drown out everything. Yes, my doors are dead and mids in pods so thats not the issue. I would not mix speakers though if you want 2 sets of mids in ur front doors then they should be the same models as well as the tweets. Do as I did run 1 set for awhile and see if its what u like if not then glass them up and add a second set. Of course you would have already made the doors dead and all that good stuff.
Keep_Hope_alive,This also comes down to about 70-80% install. Poorly installed speakers, large cabins, or too much sound deadening can really kill a high powered set of speakers.
I'm pretty sure we dont have the same bmw, but i would bet their door designs and the materials used in the doors are very similar. If you dont mind, I would really like to talk to you about how you sound deadened your door, and what you did to your speakers(i.e. clay, mdf baffle, etc.) I read the sound deadening thread, but without pictures of "holes in doors" i was confused, and i know my doors will be different than someone else's doors, so it would be nice to see what another bmw owner did. Plus u said too much deadening is bad? I didnt know u could deaden it too much. So i would really appreciate some advice there, and i can send u some pics of my door panels later, gotta go take a couple exams! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Fi-brations, (cool name BTW //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif)
My BMW is all stock. Its an '02 330xi with every option from the factory. It has the 12 speaker Harman-Kardon option that is basically a 3-way active stage, rear speakers LPF'd at about 3000hz, and back speakers LPF'd at about 100hz from what I can tell (sounds like subwoofers). If you hit a button in the dash that looks like a speaker, it turns the rear speakers into full-range mode so the people in the back seat can hear better. It also makes it sound like 5.1 channel surround but definitely kills the front stage presence. :-/
If I was to rate it, I would say an 7 - 8 out of 10, for all the systems I've heard. Definitely the best stock stereo I've ever heard.
I did take the driver's door panel off to replace the lock mechanism and found a moderate amount of deadening behind the panel and in the door. There are a few holes that could be sealed up, but nowhere near as many holes as most cars I've seen.
To seal the holes, you can simply cover them with sound deadener up to about 4". Large holes will need a blocking plate made out of plastic or plywood. MDF will soak up water and turn to mold unless you fiberglass it in. Seal the plate to the car with some screws and autobody sealant. Otherwise you can use automotive adhesive, but it will be a pain trying to get the plate back off.
By "too much deadener" I mean the people that have 2 layers of regular deadener, a layer of closed cell foam and finally a door panel. When you stack up all that deadener, it turns your door panel from being a speaker baffle/box into a dead chamber. Its like playing a speaker in a padded/muffled box compared to having some hard surfaces in the cabin. Similar to how drummers stuff a pillow in their kickdrum to deaden and muffle/deepen the sound. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The key to a properly deadened vehicle is stopping panel vibrations and adding mass to resonant panels. If you have door panels rattling, that not only contributes to noise but creates a loss of energy since the speaker is vibrating in its baffle. The panel needs to be stiff. Some people say you want to "decouple" the panel from the door by isolating it from the door with deadener. I don't agree. In my testing, having a door panel made of wood and fiberglass rigidily mounted to the door sounds a hell of a lot better than the typical plastic and vinyl/cloth covered door panels found in OEM. To me, its the equivalent of a very large solid enclosure and gives the speakers the best environment to perform.
Deadening the floor, walls and roof is good for decreasing your cabin noise which gives the perception that your stereo is playing louder, since you don't have to crank it up to overcome the noise.
If you simply seal up your doors and run 1 layer of deadener on all panels, maybe 2 layers on the floor and wheel wells since these make the most noise.....you will have one fine environment for whatever speakers you choose. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif BMW designs and builds their cars to be quiet from the factory, so they don't need a lot of help. They are notorious for "******* power" in subwoofer installations because the trunk and cabin is already heavily sound deadened. You find a lot of owners having to run more power just to overcome the deadening. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yes, but double the volume control setting isn't double the power. Human hearing sensitivity is logarithmic, and a properly implemented volume control should have a log function.
Some speakers don't "come alive" until you reach a certain power point. A speaker or especially a subwoofer with a higher RMS rating has a stiffer suspension and/or heavier coil to handle the added power. This is going to take a few watts just to get it moving.
At lower volumes/power, a more sensitive speaker with a lower RMS rating will "generally" sound a Lot better than a higher rated speaker.
I'm dealing with that now. My car is really quiet and I often play my system at low volume levels. It's a real challenge to find a speaker that can play cleanly with good midbass at low levels yet get loud when I want it.
i didn't know we were talking about doubling volume control settings - that is arbitrary and not a good metric for anything. i focused on what i felt was useful. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
good linearity is difficult - in part because of the sensitivity of the human ear with low and high volume levels.
thanks for your input guys, the more we share, the better.
Fi-brations
Fi-brations
Memphis, TN
keep_hope_alive
