Does length Amp is from battery matter with..
mightycrappy
Well first off let me say I am looking at some 1KW to 1.5KW RMS amps. Probably closer to 1KW though.
Anyways, I read that the further away your amp is from battery the smaller the gauge wire you should use.
So I was thinking of using 4gauge in an SUV. A Mid Sized one. So it's a good 15ft or from cargo in back to battery (I haven't actually measured, just a tired as hell guess).
So being in an SUV and having to run the power wire all the way back there. Should I get like a 2 gauge or something? Or will 4 be good enough for that wattage?
Well I'm going to bed.
Thanks
BTW someone buy my paintball gun so I can buy an amp. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
lol
4 gauge wire is good up to 1400 watts, IF I remember right, but it never hurts to run larger wire.For instance I only have a 300 watt amp but ran 4ga wire,becaus I may upgrade the amp/subs in the future and that way, I don't have to rerun anything.
Well I'll most likely never plan on upgrading. I was originally only wanting about 300-500W sub, but ended up getting nice cheap 1000W+ Sub. I have kids so that right there is probably overdoing it.
Just didn't want to spend the extra money if I didn't need too.
Was offered an MA audio hk401sx, would that need 2gauge if I did go that route?
Or no since I would only be using around 1.2KW RMS? Also heard those are power hungry amps, so would I end up having to go to 2gauge?
mightycrappy
mightycrappy
QCAIA
mightycrappy
BP1Fanatic
BP1Fanatic
