Does a fuse bottleneck my current flow?
ghart999
I am just wondering if running 200A of current through the diameter of a 200A fuse is destorying the whole point of low resistance with big 0 guage wire.
I mean the fuse is 1/00 the thickness of the 0 gauge, so it almost seems like this is a problem? Also what about using crimp on 0 gauge terminal rings? Is that thin amount of metal causing problems with resistance? Should I use those big thick screw in terminal rings instead or should it not matter?
Thanks.
Yes, it's tiny compared to the power wire, but it's also very, very short in lengh. So you get a voltage drop across the fuse, but the protection you get from it is certainly worth the minor drop //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I like screw terminals instead of the crimp ones simply because I'm lazy, and like the clean look of a screw-on terminal instead of hammering the shit out of a crimp of that gauge //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
There is always a resistance when you are using any fuse, but whether or not this difference is noticable is a different story. Whether or not it would be worth taking the risk running an unfused wire is yet another story.
If you take a multimeter set on DC volts and connect one probe on each side of the fuseholder, it will display the exact amount of voltage drop through the fuseholder. The system has to be playing for this to work. If it's installed correctly and not defective, a fuse will never cause enough of a voltage drop to be audible, until it blows.
in db drag every .1 decible matters thats why most that compete take the fuses out.
ghart999
ghart999
Denver, CO
audiolife
