dodge caravan wiring
ebin5446
so i have a 1999 dodge caravan and i just got a kenwood kvt-512 in-dash dvd i already have a 12" audiobahn immortal with a 1600 watt power acoustics amp and a 8 fared cap to that amp i also have a rockford fosgate amp powering my door speakers anyways when i wired in my kenwood the red light in the front came on i contacted kenwood and they had told me that that light meant there was a short somewhere. i checked my wiring and everything is good but i do know that there is a short in my vehicle somewhere because my speedometer and rpm meter will drop to zero whenever it wants to. so i am just wondering if that could be the reason the kenwood will not work and what can i do to remedy this problem? all help is appreciated.
i have the same vehicle and i know in mine i have a poor ground so i have to ground the headunit to the steel of the car. I dont know if that will help you but i know its a problem in my van that i had to fix.
i do not believe its the ground, because the hu gets power it just wil not let the screen come out or turn on whatsoever, but i will try that. i was thinking that i could just rewire the whole thing and bypass all the factory wiring does anyone know if that could work or any other suggestions?
Your speedo/tach dropping out to zero probably isn't a short unless there are other gauges beyond that going out. I'd check for a damaged or loose speedometer cable on the transmission. It'll be a steel cable wrapped in hard black plasctic coming from your firewall into the ****** somewhere.
the temperature guage also drops to zero so i doubt that it is just a loose cable for the speedo/tach because they all happen at the same time and i will try changing the ground but in case that doesn't work are there anyother suggestions.
ebin5446
ebin5446
atlanta, GA
ebin5446
