thats why i said my G...as in we both have G35 sedans....some motors don't end 93 octane....ive seen motors on dyno's make less horsepower on 118 race gas than 100 octane...just because the motor doesn't need it for the compression ratio so lowDepends on the car and driving style.
87 octane requires less heat and pressure to combust, but can pre-combust at high engine speeds, high stress (i.e. towing), and/or in high ambient temperatures. This can result in pre-mature engine failure.
Always use the octane level your manufacturer recommends.
Just curious....are you serious? Like, do you honestly believe that is true? That was such a ridiculous statement that I can't tell if you were serious or not, so good work if thats what you were going for.No if you use 4WD, that is less power needed per wheel which should improve your MPG. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
This is 100% wrong //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifNo if you use 4WD, that is less power needed per wheel which should improve your MPG. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
An AWD drive vehicle will weigh more due to the transfer case. Added weight = less MPG. That's a factual //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifNo if you use 4WD, that is less power needed per wheel which should improve your MPG. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I'll definitely give that a shot. I'm running on E right now. Hopefully I have enough to get home. Otherwise AAA will be expecting a call.i never checked it specifically.....but it was enough to tell the difference just by driving it...
no, it can't //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifcars run harder, usually starting your car for a while before driving it wastes some gas, and having the heater at full blast can have some effect too.
I was getting 300 miles with a full tank in the summer and now i get around 265.
transfer case?An AWD drive vehicle will weigh more due to the transfer case. Added weight = less MPG. That's a factual //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
