i see what you mean, my definition of loud is being able to feel and hear the bass clearly and feel pounding in my chest but not loud enough to annoy anyone on the steet. I'm going to use a 1^3 SEAlED enclosure and am not competing. All i want is great lowend with some decent out put, nothing too big, basically loud but still being able to hear the music.You can make a sub do a lot of different things simply by changing the install...
"Bump" is a meaningless term as everybody's definition of what's loud varies. SQ-oriented drivers can get loud, but if you're going for SQ, the whole point is not to have it the subbass be overbearing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A high tuning and high crossover point will exaggerate subbass with pretty much any woofer.
alright thanks, could a sq driver like the diyma atleast hit around 125 -130 db's ?Sounds like you're on the right track...
A good friend of mine has a 15" Brahma MKII in a 3cF sealed enclosure, and he can tune the Xovers and EQ to where it'll kick you in the nuts...but can blend it very nicely with the front stage when needed.
Building a box slightly above a "traditional" alignment (.707 Qtc) will help to give you that chest-pounding sensation. Just don't go too small.
With a good install- sure. Don't see much point myself. Y'know 110dB is front stage at a rock concert, right? How much louder is necessary than that? //content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gifalright thanks, could a sq driver like the diyma atleast hit around 125 -130 db's ?
C'mon, you know that's A-weighted //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifY'know 110dB is front stage at a rock concert, right? How much louder is necessary than that?
With woofers of the same size, similar quality, and similar installs, the 2 woofer setup will almost always win over the single woofer setup. You want impact, the dual BM setup is the way to go. Personally, I'm all for the cheaper direction, but then I'm cheap. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gifso now i'm going back and forth between the two following setups
sundown audio 1500
2 si bm's (12")
2 fiberglass enclosures
or
jbl px300.4
1 12" diyma
so basically the second set up is about $400 cheaper
would there be any difference in output and impact during normal listening levels?
and which would you take?
