DO i have enough power.
mega1268
I am planning on getting a x1200.1 and a x200.4 from xenon. The x200.4 wont be pushed that hard at all. and teh x1200.1 im gonna set for about 1000 watts. my question is i know i should do the Big 3 upgrade. i have a Optima red top and i upgraded to 130 amp alt. Will this be enough to power both. Cause before i had a kx1200.1 to a 13w7 and it sounded like garbage threw the transition notes and it seemed like i think it was because of massive voltage drop.s Will i be ok like this. No SPL comps just a loud daily driver.
****, amps now a days have adjustable power outputs? I'm crious as to what you mean by setting the power output to 1000w
Using the formula for setting your gains via AC Voltage of the outputs using a test tone. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
i have the amp already. and thats not the point. Do yout hink those amps will draw more then 130 amps. or w/e a normal car uses to operate with just the headlights and normal driving funtions. minus heat cause i know that sux up alot and its almost nice out here.
if you already have em why dont you hook em up and find out?
There is no way to decide that without actual in-vehicle testing... Install the shit and see if it dims, go from there.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
DING DING DING!!!
Smartest thing I've ever heard this kid say.
nG
nG
Oh, so now the general opinion has changed from what is was a year ago when I left? I'm not fighting the facts of what goes on inside electricity, I'm just curious. I know before I left, anytime someone said "I'll jus tturn my gain down", everyone laughed at them...
Power is dynamic. An amp does not put out full power 24/7 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
nG
the 200.4 is a current wh0re. fuse rating is 120amps.. I run two of them (well when they work), have done big 3, 200 amp alt, and a stinger power2 battery...and still get voltage drops to 13.5-13.0 when playing rap full tilt. Only a few songs will cause drops..but i can do it if i try.. with out clipping (to my knowledge).
I bet you will be fine if you only run the 200.4 @ 4ohm for mids/tweets.
nG
mega1268
mega1268
NY
RandyJ
ThxOne
    May 13, 2026
