Dmm...
bgowdy
Heroes are remembered, but legends never die
Ok i dont like to make multi threads, i tried bumping up an older thread about dmms but couldnt get answer.
Im just trying to set my gain i used the online calc to get the correct voltage for the rms that & impendence that i would like to run. I also know that i use ac volts on dmm. However i dont know which setting to use on the ac volt side. I gives too options. It ac volts 200 or ac volts 750. I kno it isnt great but i have a ""Scosche digital multimeter TK12V"".... Also do i use a bass sweep to set the gain with dmm?????
Thanks in advance.........
thanks if only everyone else responded that easy lol.. How u like the PD2000.1? I just got my installed. Its a ***** running double wires. and thanks for the db drive info i picked up the last one they had lol
mine is doing fine. got it installed tonight..peep my build.
and if you ever want to sell it PLEASE let me be first on your list. i need another. i went to order today but you had beat me
Looks good and yeah i actually ordered it the same day u was talking about it. I remeber u said theres was 2 left then when i went to order they only had 1 left so i ordered it. I will be posting vids & pics of my new set up once i get my new box done.
because thats the only way for a dmm. im renting DGAF's o-scope to set different freqs so i dont clip. if you want give him the renting fee and ill ship it to ya when im dont if its ok with him
ok instead of making a new thread im going to try to bump this thread........ i have a question in regards to this. i have heard so many diff sides to setting amp with
dmm as far as the freq to set with goes so im still not sure. so trying to get this done right. but here is my question, if im peaking at 50hz. should i use a 50hz tone to set my amp with the dmm.....
thanks
bump......
dmm as far as the freq to set with goes so im still not sure. so trying to get this done right. but here is my question, if im peaking at 50hz. should i use a 50hz tone to set my amp with the dmm.....so ttt......
thanks
bgowdy
bgowdy
Campbellsville, Ky
bgowdy
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
