Dmm
MTXThunder9500
Fo Shizzle
well im having some problems with my 20.1 it doesnt seem like its putting out enough so im going to try and set the gains tomorrow and i have been reading through the gain tutorial and im curious what is a good Hz to play when doing this???? and alos someone tell me if the math is right
sqrt(1800*1)=42.43 volts????
this is my first time doing this so i wanna try and get it right
What HU do u have? u used a 50hz test tone @ 3/4volume? Set the gains at 42.43 volts at specific voume(3/4), and play music up to that specific volume.
i have the panasonic ghost with the touch screen
one thing i was wondering is what should i have the dial set to on the Dmm to check all the things on the amp and subs
i noticed in the jl tutorial they only disconnect the positive from the speaker terminal and not the negative does it matter if i disconnect the neg too?
it also says to turn down all processing but if this is just a sub amp can i leave my treble turned up?? I also normally listen do the deck at -12 for bass cause then i get distortion from the fronts cause if i turn that up it also turns up the bass on all the speakers including the sub as well
i got a question to set the gains where do i turn the dial to on the DMM? it has.....
DCV then it goes 1000, 200, 20, 2000m, 200m
ACV 750, 200
im assuming i need to have it in one of those areas but im not sure at which number
thats a pic of the DMM i borrowed from a friend also where does it need to be at when im checking the ohms on the vc's
MTXThunder9500
Fo Shizzle
MTXThunder9500
Fargo, ND
MTXThunder9500
NorthFramingham
    Jun 30, 2026
