DMM question...?
snarl2004
On my DMM i was wondering what settings i use to find the following:
1) Which setting do i use to set my gain
2) Which setting do i use to checy the volts going into my amp or what my battery floats at
3)It says it can measure RMS if its true what setting would i use for that?
Mine looks like this:
1) Which setting do i use to set my gain =ACV (AC voltage) when connected to speakers or amp output.
2) Which setting do i use to checkthe volts going into my amp or what my battery floats at=DCV (DC voltage)
3)It says it can measure RMS if its true what setting would i use for that? =That would also be ACV but you'll have to Google around to find the formula to use.
Maybe look over at http://www.the12volt.com/caraudio/caraudio.asp for starters.
Also Google search around for your manual for your meter.
2) Which setting do i use to check the volts going into my amp or what my battery floats at=DCV (DC voltage)
snarl2004
snarl2004
mass
88Vette
