NOT LOOKING FOR ANY TRADES AT THE MOMENT.
DLS
Ok I have the following DLS A series Ultimate amps up for grades. All are in great condition and are 100% fully functional.
DLS Ultimate A1: $145 shipped in the US. Condition (Nearly Mint!)
2 x 45 rms @ 4 ohms
2 x 80 rms @ 2 ohms
2 x 120 rms @ 1 ohm
1 x 160 rms @ 4 ohms mono
1 x 240 rms @ 2 ohms mono
http://dls.se/econtent/files/454/manual_a-amp06_eng.pdf
DLS Ultimate A3 Dual Mono: $335 shipped in the US. Condition (8.5/10)
2 x 150 rms @ 4 ohms
2 x 270 rms @ 2 ohms
2 x 425 rms @ 1 ohms
1 x 550 rms @ 4 ohms mono
1 x 870 rms @ 2 ohms mono
1 x 1000 rms @ 1 ohm mono
DLS Ultimate A4: $415 shipped in the US. Condtion (7.5/10, Has some marks on the Heat sink see photos.
4 x 85 rms @ 4 ohms
4 x 145 rms @ 2 ohms
4 x 220 rms @ 1 ohm
2 x 250 rms @ 4 ohm mono
2 x 400 rms @ 2 mono
DLS - Products
Alto Mobile
I have a few Brand New in Box (plastic wrapping still around box, never even been out the boxes) Alto Mobile Fullrange Class D amps. These are the best sounding Class D amps I have ever listen to or used and some the the best sounding midrange amps period. These are small with great power and sound great. Some of the best midrange amps I have used, somewhat of a tube like warm sound. These amp are not 2 ohm stable, but they make the same amount of power into 4, 8, 16, or 32 ohms, However the can be bridge, but only input 8 ohms or higher!!!!!! Great for those of us who are using home or pro audio drivers.
http://i69.photobucket.com/albums/i7...e/DSC02695.jpg
THD:………………………………………………….0.05% @10Vrms
Residual Noise:……………………………………
Xover:………………………………………………. HP/ LP/ FLAT switchable. 50Hz - 500Hz, 12dB/oct.
Input Gain Range (MAX - MIN):…………………400mV to >15V
Operating Voltage:……………………………….11 - 16V DC (negative ground)
Output Efficiency at Full Power:………………>90%
Protection Circuitry:……………………………..current (LS output), voltage (+/-), temperature
Idle Current (no signal):…………………………0.6A
Standby Current, REM input low:………………1mA
Size:…………………………………………………229 x 175 x 37mm (9” x 7” x 1.5”)
2 152 2 channel: 75W X 2. $155 shipped in the US.
2 150m mono: 150 x 1. $155 shipped in the US. (These I truly don't want to sell, but it is for the great good)
Dayton Audio
I have a great condition set of Dayton RS100.
I also have a great condition set of Dayton RS150.
SOLD
Hertz
I have Mint set of Hertz Space 1 1" soft dome tweeters. These are some of my favorite small format tweeters. These are the same tweeters as the ML28 tweeters to comes in the Hertz MLK165 comp set, just with an all black grille.
I have a Mint set of the Hertz CX20 Passive crossovers. These are the Passive that come with the MLK165 comp set. Great passive units. With the above tweeters and I nice mid/bass driver (The H-Audio Ebony's are a outstanding match for the this set. Sorry for the shameless plug!)
70 shipped in the US.
Eclipse
Near Mint Eclipse 5303R. Love these unit as many now I an old school Eclipse head unit fan. The unit is Near Mint. I have the manual, cage, wiring harness, remotre and trim ring, everything but the original box, but you will get it in a eclipse box.
$115 shipped in the US.
Eclipse DDL (Direct Digital Link) system some else I said I would never sell, I was going to use it in an old school build I had planned, but here it is. You get a system the is in very good condition for its age. You get everything but the ECD-510 head unit (which I’m keeping).It can be used with any head units as it has analog input Or you can use it with any source that has a toslink optical output, Also the Changer has optical out so you really don’t need a head as it can be controlled from the EQR-2140, DDL Touch Logic Controller. It has to many features to list, see the link below for full specs and info. Come with all cables need for connection.
Coming soon
$220 shipped in the US.
Other Items
I have a set of the TBI HDSS Tweeters. I change the color to a saint black, looks really.
50 shipped in the US.
I have a set of Vifa MG10 wide-band midranges. These are some great sounding driver. These are the 4 ohm models.
Vifa MG10MD09-08 3.5" Fiberglass Cone Midrange from Madisound
$50 shipped in the US
I have 5 units of the super rare MIT AutoTerminator Pro Speaker Articulation Modules some more items I said I would never sell.
These units are of direct origin from the Award winning MIT Oracle Technology. They where marketed for Auto Audio used, but can be used in either Home or Auto. These unit where available in 3 levels, Street units (entry level), Competition units (audiophile level) and the Cream of the crop Pro units ( Epert/on holds bore Level). What you see here are the PRO units!! These units had a retail value of $1200 for the pair. What I have are 2 High/mid units in chrome which where the production units. I also have 2 more High/mid units, but are in the prototype casing and lastly 1 Mid/low unit in the Prototype casing. That’s 5 units in total, that’s a whooping $3000 in modules.
$350 shipped in the US.
I have a used Pioneer FH-P4200MP Double Din CD/Cassette (I said Cassette ) Player. I give this unit a 9/10 only because it is a very small mark on the face directly under the model number. Other then that is perfect. It was used for only one month maybe a little less.
Arc Audio FD6000 Mid/bass drives and grilles only (no tweeters or passive crossovers), they are like new hooked up, but never seen power. I do have the grilles for them.
http://www.arcaudio.com/archives/fd_comp.pdf
$40 shipped in the US.
I have a pair of amazingly rare Scanspeak 13F wide-band drivers. There was only 5 pair ever made. The drivers are base of the Scanspeak 13M/8640 motor ( Scanspeak Classic 13M/8636-00, 4" Midrange from Madisound ), it those use the Scan SD-1 (Symmetric Drive short circuiting). This is a very detail driver and in some cases sound better then the 12m. The pyramid cones both have very small dents in them but nothing crazy or any that would come close to effecting the sound. Said I would near sell these either, but.....
Here is all the info I have on them:
voice coil is 14mm and is centered 60% in gap
Nominal excursion 5mm one way.
8 ohms
FS 100hz
Power handling is said to be 50 watts rms without highpass crossover. So add a high-pass filter and they will handle quite a bit more. I test them one DLS A3 and took the power like a champ.
Impedance is said to nearly flat from 100hz-15khz, so it a very easy load for amps to drive.
Efficiency: 82.7db
Sensitivity: 85db
225 shipped in the US.
I have a mint condition Phoenix Gold TLD66 6 Channel line driver.
SOLD
DLS
2 x 45 rms @ 4 ohms
2 x 80 rms @ 2 ohms
2 x 120 rms @ 1 ohm
4 x 85 rms @ 4 ohms
4 x 220 rms @ 1 ohm
DLS - Products
Alto Mobile
Dayton Audio
SOLD
Hertz
Eclipse
Coming soon
Other Items
8 ohms
FS 100hz
Efficiency: 82.7db
Sensitivity: 85db
SOLD
