dj rackmount amp?
right...so 4ohms no worries....ive just never heard of people using these for subs before....seems alot cheaper than getting a plate amp....only thing i can think of is that it might be a bit big and inconvenient
ahh....i see....well, i dont care if its a knockoff as long as it puts out its rated power....or is it just a pos like pyramid or pyle?
Many amps even high end amps may not meet rated power. That's not a bad thing,
just look at what the amp can do and then judge it fairly. This amp is rated for
600w @ 4 ohm bridged. I would estimate 300w @ 4 ohm bridged for subs
under heavy stress. Is $100 worth it for a 300w sub amp? You decide.
204
407
492
  • Locked
785
Amp
569
meistah
meistah
Vancouver, BC
dbaudio
