Distro/Wiring Question.
Chancellor
Huey Freeman
I'm sure that there are plenty of threads about this around.
But at times searching>me.
I will eventually be running:
2 Sundown 1500d's
1 Sundown 100.2
Temporarily I'll just use(until i my electrical upgrades are complete):
1 Sundown 1500d
1 Sundown 1000.2
I'm curious as to what size fuse I would need with this setup.
I'm also curious as to whether a distribution block with 1/0 inputs and 4ga outputs would be sufficient enough to power the sundowns.
Thanks in advance.
C.
^+1. I'm actually gonna be runnig the same in the next week or so. except there'll be a 100.4 in the mix too
Off 300amp fuse and 1/0 kicker hyperflex. Might just keep the 4ga run thats already in the car and use it for the 1500 if it's long enough to reach the end of the trunk, otherwise i may just rip it out and use it for the big 3
don't know what electrical upgrades you'll be doing. but if you're gonna add another battery. just run a 1/0 ground wire to the rear from the front battery as well. then you can just run everything off of the battery [use it as the distro]
For the time being I will only be using 1 battery. But in the very near future (next few weeks) I will be adding 2 more.
If my idea isnt the greatest.
I'm open to suggestions in wiring.
Whether it be to fuse every power wire from the amp. Or, to go ahead and use 1 300 amp fuse and wire them to a distro.
Chancellor
Huey Freeman
Chancellor
Hustlers Paradise
ultimate157
michigan born
    May 14, 2026
michigan born
    May 14, 2026
