distro block question
Matt 9
i just bought a JL Audio 250/1 for my sub. i was going to try and find a 360/4 for my front and rear speakers. i'm currently running 8 gauge power and ground. What kind of distro block would make adding the second amp effortless? I have never ran more then one amp, but from what i read, my interior speakers would really sound good with an added boost. my current amp has a fuse and i have an inline fuse next to the battery. i'm just going for sound quality and really not trying to break the bank with high output alternators and new batteries. i dont plan on competing, i just want my ride to sound good. Also, i dont remember if my head unit has more then one pair of rca's out. So i was curious if i would have to re run all the speaker wires or get a new deck first that has multiple pre outs?
any help would be great. thanks.
if you going to run the two amp i recommend getting a headunit with mutiple rcas output
the getto way be if you have one rca out use a y-jack not really recommend
i also recomend bumping the 8G to 4G then use a distro to go back down to 8 if you need to
pm if you need distro i got one forsale
cool, i will pull the deck out this week and see if i have more then one set. i was going to upgrade the deck soon anyways. this would be a good reason. i would rather have it done right then ghetto.
The JL amps should have line outputs so you don't need y-adapters, LOC's, or a new HU.
An 8awg feed is good for 60A, or 400W. So your plan to just add a distribution block is fine. Non-fused is also fine if the outlets are also 8awg.
Yes, an amp will greatly improve clarity.
Matt 9
Matt 9
West Springfield, MA
Matt 9
michigan born
    May 14, 2026
michigan born
    May 14, 2026
