Distribution Question?
MrSplorDie
Hey, I am planning on putting 2 amps in my car a Optive 2000d and a Fosgate 300a2, so basically for the power, I should run 0 gauge to a distribution Block, the 4 gauge out right? and then run 0 gauge from the grounding spot then 4 gauge to the amps right? But where should i but the distribution block under the hood or in the back?
in the back near the system....Run 1/0 to the distribution block then depending on how big of a wire each amp takes...run that size to each amp...and the same size for the ground...
I just didnt want to run that thick *** 0 gauge all through my car //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
None of the rest of us here (that have runs of 1/0awg cable or larger) particularly cared for having to make our runs either - but the old adage of Do It Right The 1st Time So You Won't Have To Do It Again particularly holds true here.
just do it and get it over with dude. it'll make any and all upgrades in the future alot less of a hassle when you want more power but gotta replace your wire. do it now, get it over with, save the hassle. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have same problems...i wanna run all 4 guage all through system...mut my amp dont need 4 guage that can take 8 guage..so i chose to run 4 guage from battery to block then 8 guage to amps..i have smaller sub amp and 4 channel
MrSplorDie
MrSplorDie
Detroit, MI
helotaxi
