Dist block for my system?
cloud_171
Hi, I bought a 4 gauge kit from KnuKonceptz for my ZRS-10 and got the Nine.2 later. I completely forgot about hooking up the second amp. The rest of my system is in my sig.
I plan on running 1,000W on the Cadence and 200w from the nine.2. Could I do 4 gauge to 4 gauge and 8 gauge in one of these with my current amp kit: D Block? or do I need a 0 gauge kit? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
edit: For some reason my sig isn't showing up but here is the rest of my system:
JL W7 12" in a sealed enclosure built to JL Specs
DLS UR6 (on the way)
Cadence ZRS-10 (150W @ 4ohm, 1500W @ 2ohm, 250w @ 1OHM)
eD nine.2
Pioneer P5900IB (temp)
KnuKonceptz KLM-4 4 gauge amp kit
Alright, so I did some numbers and it comes out to be 100 amps max for both amps. According to the wire guide 4 gauge should handle 140 amps, so technically all I need to do is get a dist block and a new fuse? or does the KLM wires unable to handle the full 140 amps?
haha yeah I'm slightly above budget, all I need is a headunit. I don't think I'll ever pump it to max, my current speakers at home only do up to 75w and I've yet to max them out. Thanks guys.
The other reason for going 1/0 now is so that it's in place for future upgrades. Unless you're the 1 guy on CA who doesn't upgrade. LOL
I don't think that person actually exists...he's a myth.
If you were thinking of running separate 8 gauage for the smaller amp, you might as well save up and get a 1/0 kit and install that. It would make it a much cleaner install. But if I were in your situation I would just keep the 4 gauge and use a distro block. Just be conservative with the volume control and make sure to set your gains properly. Good luck.
cloud_171
cloud_171
New York
XanderMoser
