Directed D1200 amp
dgaf
Swollen Member
755
727, FL
Directed D1200 Amp
8.5/10 Cosmetically
10/10 Functionality
600 watts x 1 chan. @ 1 ohm
400 watts x 1 chan. @ 2 ohms
300 watts x 1 chan. @ 4 ohms
$75 shipped
I also have an Alpine Type R D2 12" sub for sale, the perfect match for this amp.
http://www.caraudio.com/forums/subwoofer-classifieds/510270-alpine-type-r-1222d.html
Will cut a good deal on the sub and amp sold together.
Open to trades as well.
u dont have the cover? mine didnt either
Not sure what's up with that. Do they ever come with one? The only time I've seen em was on the newer style ones, never saw one on these older models.
just realized that two of the screws are missing. it will work fine if you're going to use it mono, but if you want to use both channels, we'll need to find a couple screws. i can probably find some at work, so if it's important, let me know, and i'll look for some.
free bump
For everyone's information you can find the right set of terminal screws for almost all the amps at Lowe's, even those hex key ones.
Awesome, thanks for the info
120
358
  • Locked
662
Amp
478
dgaf
Swollen Member
dgaf
727, FL
dgaf
    Jun 1, 2024
    May 31, 2024
