Directed Audio D2205 5 channel Amp!!!
  • 1
andrewtexas123
Directed 5-Channel Class D Car Amplifier
Bass Remote Included
RMS Power Rating:
4 ohms: 80 watts x 4 chan. + 280 watts x 1 chan.
2 ohms: 125 watts x 4 chan. + 400 watts approx. x 1 chan.
1 ohm (subwoofer channel only): 600 watts x 1 chan.
Max power output: 2200 watts
High-Speed MOSFET switching power supply and complimentary bi-polar outputs
Thermal, DC offset, reverse polarity, short circuit, and over/under voltage protection
Programmable features controlled via ESP serial databus and Directed's Bitwriter tool
Variable high-pass filter (20-250 Hz)
Variable low-pass filter (50-500 Hz)
Subsonic filter for subwoofer channel
Switchable Line Output/Subwoofer Input
Switchable 8 dB Bass EQ
Variable input sensitivity optimizes match with different signal sources
Chrome plated wire and rca jacks ensure maximum signal transfer
Rugged extruded two piece heatsink and cover
Unity gain pass through rca jacks
Adjustable input sensitivity: 500mV - 8V
Output for optional cooling fan / LED lighting
Dimensions: 10-1/4"D x 25-3/4"W x 2-3/8"H
Used working condition! Missing the logo on the front of the amp has the bass knob but not the wire to connect the two.
$220 shipped
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
193
andrewtexas123
andrewtexas123
Danville, Ca
andrewtexas123
    Jun 1, 2024
    May 31, 2024
