SlickCMRick
instead of the 1606d i went with the opti2000d that does about 1700w at 1 ohm, and it was benched to do that. Its rated for only 1600
Of course it was from bad quality. I have heard of people describing very similar situations as myself with the DEI refurbs. If you plan on buying it, good luck.Thanks for info, it's probably only gonna be at 1/4 gain since it will be pushing (2) 12" type R's. But some of those defects you talk about are probably not from stress, but from bad refurbish quality.
took me 15 minutes last night to get it in lmao.....ill have pics in a week or so when i get everything installed.When do you get the Opti2000d?
How did your 5 cubes at 34hz box fit in the nissan?
pics?
i have that same amp and it is not 1-ohm stable, but it is a very strong amp I`m powering 2 SI Mags with it and it makes my back window flex like crazy and I`m not running it at 3/4 power, I would buy that amp if I were you and be happy I am make sure the amp can breathe in an open space.For only $240 ???
http://www.ikesound.com/product-product_id/2465
This seems like a great deal, doesn't it? I was gonna get a 1606d, but now that I've seen this deal I think I may get the 2400d instead.
What do you guys think?
Oh ya what does this do at 1 ohm?
THanks!
Thanks for your opinion on the 2400D I will deeply consider purchiasing this amp in the next few days.i have that same amp and it is not 1-ohm stable, but it is a very strong amp I`m powering 2 SI Mags with it and it makes my back window flex like crazy and I`m not running it at 3/4 power, I would buy that amp if I were you and be happy I am make sure the amp can breathe in an open space.
I have mines at 2-ohms,i have dual-2 ohm sub wired in series-parallel to give me a final 2-ohm load with each speaker getting about 1200 watts each...at 4-ohms the will produce 1400watts or more . These amps will do their rated-power and some..btw they are heavy too.Thanks for your opinion on the 2400D I will deeply consider purchiasing this amp in the next few days.
Have you tested it at 4ohm? If I get it thats what I would have to run it at then since its not 1ohm stable. Should still work fine since its just gonna power a couple Type R's.
I backed out of the ampman because original owner told me some stories about that amp and the company that fixed it, and the 2nd one I had one and loved it but its sold now.
I have read that it wasnt a good idea to run them at 1ohm.
i think its the newer DEI amps that are rated for 1 ohm also.
