dimming head lights will this help?
TIGERFOR2
The Storm series solenoid from Lightning Audio is an efficient and reliable way to add a second battery to your vehicle. The S200 isolates batteries without any voltage drop, and is compatible with all types of alternators and charging systems. Simply connect the relay to operate when the ignition is turned on. Your batteries will remain separated while the engine is off, preventing voltage drain.
Features:
200 Amp Contact Rating
Water-Resistant Phenolic Plastic Case
100,000 Mechanical Cycle Life
nope. That would not help.
Dimming headlights are caused by there being insufficient power to maintain the systems voltage @ ~14.4V. A second battery would only add to the strain on your alternator (until it is charged, but after every bass hit it would lose some charge).
The best solution is to get a higher power alternator, or get your current one rewound so that there is more power available.
TIGERFOR2
TIGERFOR2
ALBANY,NY
CarAudioAddict
