I am putting these amp up for sale because I went from a large car to a Mini Cooper and now my room is extremely limited.
Product Brand & Model:
Digital Designs S4b amplifier.[/u] Very, very nice amplifier. Gobs of power and very clean, I loved it. It would be in my new car if there was room.
Channels 3 and 4 CAN be bandpassed.
Specs:
Staggered 4-channel amplifier Class AB
Bridged 360 x 1 + 720 x 1
Channels Can be used as 2, 3 or 4
Cont Power at 2 Ohm 180 x 2 + 360 X 2
Cont Power at 4 Ohm 120W x 2 + 240 x 2
Dimensions (Inches) 17.875 x 9.125 x 2.5
Shipping Weight 16 lbs
Digital Designs M1c mono amplifier. Very good amp as well. It's definitely more powerful than the ratings imply, which is nothing to sneeze at already. Once again, this would be in my car if I had the room for it and the 4-channel above.
Channels 1
Cont Power at 1 Ohm 1150W x 1 @ 12v
Cont Power at 2 Ohm NA
Cont Power at 4 Ohm NA
Dimensions (Inches) 13-3/8 L x 6-7/8 W x 2-1/8 H....15-1/8 L w/ mounting feet
Dynamic Power 2500 x 1
Efficiency Thru Output 87%
Input Sensitivity 8V - 0.2V
Shipping Weight 11 lbs, 5 kg
S/N Ratio >100dB
Tested THD ≥1%
Tested Voltage 12v -14v
Variable Bass Boost NA
Variable High Pass Filter NA
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
Condition of all items:
Both amps are in like new condition minus a couple very small marks on the mounting flanges. Beautiful amps.
Used for about 3 months total. Sad to see them go......
Total Price: :
$875 Shipped in the lower 48 for the amps together.
Will not separate right now unless someone commits on each amp.
Shipping Terms: :
Included in the lower 48.
Pictures: - Unless you are a Upgraded member, or your last 10 iTrader feedbacks are positive, you must post a picture of the exact item you are selling.
S4b:
M1c:
iTrader Feedback from DIYMA http://www.diymobileaudio.com/forum/itrader.php?u=7282
Specs:
Channels 1
S/N Ratio >100dB
Tested THD ≥1%
Total Price: :
Shipping Terms: :
S4b:
M1c:
