i'm w/ you on peel n seal..I've ran it in my last 2 cars..Great stuff. The only prob i had with it is when i had a minor water leak that got it alittle wet in spots..Fixed the leaks, warmed it up with a hair drier and it was fine for the 3 years i owned it..Also 1 other thing worth mentioning. If it gets cold enough(left outside in the garage all winter) it losses its stickyness..But all you gotta do when it gets warm out is lay it in the sun for a half hour and it'll be sticky again..All the diff deadners i've used have all been like this.
No smell, works great..A++ for p+s.
Good luck getting that trunk quite, my caprice was impossible. If the plate is still movin or the metal bracket its attached to use some rubber washers in between the screw/blts.
Looks good though..I was considering getting that doubledin..Any complaints? I dont really like how it sticks out though..Is that just the way you installed it?
