Digital designs geramns
cal
]Item(s) for Sale:
dd audio ddaw5.2
american bass sqt2 sold
Specs:
mids
BL 6.01
CMS0 .55mm/N
Frequency Response 50Hz - 18kHz
FS 63.99 Hz
Magnet Weight 12 oz
Moving Mass 11.26g
Nominal Impedance 4 Ohm
Power Handling 120/480 W RMS
QES 0.43QTS0.39
QMS 4.01
SPL 1W, 1m 90.5 dB
Suspension Travel 25mm
VAS 4.75 l
Voice Coil Diameter 37 mm
Woofer Diameter 5.25" 130mm
tweets
TETERON DOME TWEETER
HIGH-DENSITY NEODYMIUM MAGNET
FLUSH/ SWIVEL/ SURFACE/ OR ANGLE MOUNTING
FERRO FLUID COOLING
POWER HANDLING: 120 WATTS MAX/ 60 WATTS RMS [tweets sold
FREQUENCY RESPONSE: 1.4K-24KHz
IMPEDANCE: 4 OHM
SENSITIVITY: 93Db (1W/1M)
12Db TWO-WAY PASSIVE CROSSOVER
both are used but fully working . the mids have some scuffs on the surrounds, but no holes . one of the tweeters is missing the terminal @ the end of wire i accidentally cut off when removing the set, not an issue simply attach a new terminal . all parts are included please see pics for better view of description. i had these ran active and it sounds amazing . if you are wondering why i have A.B. tweeters with german mids well, these tweeters are the same as the dd t2 and include more hardware . i prefer these tweets over the germans because they get louder sound great and are stronger than the germans .
145 shipped(mids only) con u.s. no trades
can do payments for the right buyer
tweets pending to stereohead69,( payment recived ) thanks for the sale and fast payment
mids still available
cal
cal
cal
