Digital designs c4a
cal
Item(s) for Sale:[/u
ddc4a]
Specs:
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
20 Hz - 5 kHz at 18dB
Variable Low Pass Filter
50 Hz - 5 kHz at 18dB
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
C4a
Cont power at 4 ohm
100W x 4ch
Cont power at 2 ohm
150W x 4ch
Damping Factor
>250 @ 2 ohm
Cont power at 1 ohm
175W x 4ch
Cont power at 4 ohm Mono
300W x 2ch
Cont power at 3 ohm Mono
350W x 2ch
Dynamic Power
400W x 2ch
Efficiency thru Output
>65%
Dimensions - mm
380 L x 235 W x 53.4 H
Dimensions - inches
14.96 L x 9.25 W x 2.1 H
Signal to Noise
92 d
3. Description/Condition:
used but fully working , amp is in great condition cosmetically and no issues mechanical . this is a fully active amp and stable down to 1 ohm per channel. i do not have the manual or original box
250 shipped con u.s.
no trades
cal
cal
cal
