Ok well, since I have yet to get a response back on my email from DDs tech department, I seek the wisdom of those who are familiar with DD woofers, and enclosure design for DDs...or even better the 1500 series specifically.
I am designing an enclosure for 2 1510s, that will be going in my Scion tC. I just got finished with all of the math, and was hoping you could look it over and make sure I calculated things correctly and didn't leave out anything (I'm new at this). I also had a couple questions concerning tuning and box size. Woofers and port will both be facing the rear of the car.
1. I calculated the box size and tuning based on the recommended 16" long port which tunes to 40hz. You'll see below since the standard DD formula came out to 3.5 cubic feet after displacements, I calculated the port size to be 56 square inches for these two 10's. I listen to a lot of rock/metal type music, so it would seem 40hz would be a great tuning for those hard kick drum notes to come through with a lot of clarity and impact. But sometimes I like to listen to rap as well, so I guess I'm concerned as to whether tuning the box at 40 would handle the low frequencies well and loud. Perhaps I'm wanting the best of both worlds here, but will tuning at 40hz perform well on both types of music or should I perhaps tune a bit lower? Like 35hz maybe? How might the construction of the car (hatchback) effect tuning and performance at higher and lower frequencies?
2. As you'll see from my calculations below, I came up with a NET internal volume of 3.5 cubic feet after displacements. Would this be too much for these two 1510s, or should I go down more around 3.0 or 3.25 cubic feet?
Digital Designs 1510 (pair) - S4
External
38 wide
13 high
19.5 deep
38x13x19.5= 9633 (gross external)
Internal
36.5 wide
11.5 high
18 deep
=7555 (4.3 cubic ft, gross internal)
Approximate NET airspace
7555x.82= 6195
/1728= 3.5 cubic feet (NET internal approx)
Port area:
3.5x16= 56 sq in. of port
56/11.5(height of port) = 4.75 inches wide (rounded off)
Sub displacement
.108 cubic ft x 2 = 373.248 (.216 cubic ft)
Port displacement
4.75 + .75 x 11.5 x 16 = 1012/1728 = .585 cubic ft.
Total Displacement
373.248 (subs) + 1012 (port) = 1385.248 / 1728 = .801 cubic ft.
Final NET Internal Volume (subs/port displacement included)
7555 - 1385.248 = 3.570 cubic ft.
Just needing some double checking on my calculations and efficiency of this enclosure for these woofers. Thanks in advance!
External
38 wide
13 high
19.5 deep
Internal
36.5 wide
11.5 high
18 deep
7555x.82= 6195
Port area:
Sub displacement
Port displacement
Total Displacement
