Diffrence between Cx62's & Cx64's
mega1268
I know 1's 2 ohm and 1's 4 ohm but the 2 ohms are rated for 150 and the 4 ohms 1 is rated for 75 watts. Is this because its twice as effiecent? Is there any audible Effect if im running it off a 800.4. which is 200x2 at 2 ohm 100x2 at 4 ohm.
Ummm... I don't know where you got your specs from but the Chamaleon sets are both rated the same regardless of impedance at 150 wrms. If you're not sure, check the ID site.
The reason why you'll get more from your amp is because the resistance is lower on the 2 ohm set.
Squeak, you trying to ruin me? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Okay I didn't realize he was getting a dedicated driver because the chamaleon set as a hole are rated the same wattage:
http://www.imagedynamicsusa.com/products_page.php?id=chameleon&type=midrange
It's best to call ID and verify because it wouldn't make sense to do it like that.
lol i was about to say. Its half the wattage im positive of that lol. They have all teh same specs besides the RMS and Ohm So i sorta put 2 and 2 together and fiqured that it would do teh same thing with the 75 watts as it woudl do with the 150 watts. When impedence goes up doesnt effiecentic-ness go up. I recall some1 saying that about the Extremis.
must be a typo cuz the cx52 and cx54 have the same power rating.although, you never know...
Yea i noticed that to. But..... like i coudlent stand if it said 50 and left out the 1 but 75 is just a completeley diffrent number. Im gonna call them on monday and see what the deal is. if there is a 2 ohm and 4 ohm version whats the point of getting the 4 ohm version. 9x outta 10 ull be getting double the power at 2 ohm's?
You shouldn't really notice a difference in either set. The only difference you may see is that with the 4 ohm set, it will be slightly easier on your amp, but, then again, assuming you have a 2 ohm stable amp, that shouldn't matter too much.
Well I guess for those people with 200x2@4ohm, there's really no need for the 2ohm set cuz that would be ridiculous headroom. Or it's also cuz some amps aren't 2ohm stable (which is kinda rare these days, but is true for a number of 4ch amps when you bridge em). Of course this is all speculation and I like to propagate false information //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
shouldent notice a diffrence? If they are getting 100 watts or 200 watts isent that a 3 db diffrence or does that rule not apply to 6"s. I dunno im just asking not saying ur wrong
mega1268
mega1268
NY
twoohfour
