Diff bewteen A/B and class D amps.
So on the MB quart discus 1000 which is a class a/b will it push 1000 rms on stock prolly 13V
doubt you'll be able to pull that from an a/b on stock.
i believe a/b range from 50%-70% effiecent. Class D around 80%
Also depends on the impedance load, the lower the impedance the less efficient the amp becomes.
I have yet to hear a full range d class, but they are suppose to sound as good as a/b
doubt you'll be able to pull that from an a/b on stock. i believe a/b range from 50%-70% effiecent. Class D around 80%
^ is the key word in that sentence.
so at 1 ohm and just say at 50% efficiancy would you say 500,600, or closer to a 1000. And how much better does the a/b class sound. Because ive had a class d and it sounded fine. Can u explain exactly what efficiancy means.
IIRC, Class D is more efficient at lower volume levels than Class AB. At maximum power that is one thing, but since Class AB amplifiers generally have to maintain high rail voltages due to their non switching power supplies, their efficiency goes out the window at lower listening levels.
ETA: I've heard reports of some car audio Class AB amplifiers being as inefficient as 25% to 40% at lower output levels.
efficiency is the energy lost to heat simply put, theres a little more to it but...
The subwoofer motor assembly is the biggest waster of power converting it to heat! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
My old mtx doesn't have a switching power supply but it sounds so good, gobs up power at low listening volumes same as loud listening. most new amps have switching power supplies which increases efficiency. to explain how somthing is efficient...
take a hose- add water to one side, same amount comes out of the other. you may loose some water inside the hose but it wouldn't be more than maybe 1% from the input. the hose is 99% efficient.
Amp- it sucks up 100 amps at 13.4 volts, you would get 1340 watts out the other end "if" it was 100% efficient. energy is lost almost everywhere inside the amp. heat is the waste.
i think its safe to say that your sub is about 10% efficeint but most subs are so that does not really matter.
Its not that the mb quart wont do the 1000rms, its that it wont do 1000rms with a little bit of current. you have to be able to supply the amp with the power it needs in order for it to do the watts you want.
Like i said whats lost due to the loss of energy
the loss of energy is natural, since your losing input energy, you would just need to supply more input energy to overcome the waste which all adds up to the facts that they use more power to make power.
I've experienced this with a 4ch running a sub and 2 speakers off of it, and running a 4ch and a 1ch. running the 2 amps was more eifficient because the 1ch needed less power to push the sub the same way the 4ch was pushing it. it really surprised me because i always thought 1 amp set-up was the better cheaper way to do it. In was running this off a 25amp power supply, running the 4 ch with 2 speakers and a sub, the power supply would be at it's peak and i wouldnt be able to push the sub all the way. When i added the second amp, i was able to push the sub to its max and the power supply was not cutting out like before.
ConwayBang
ConwayBang
conway
ahole-ic
