Diff between Parametric and Graphic EQ ?
Houndog101
My HU can be set to adjust oneway or the other,, whats the diff and which would be better for an Amateur like me to use ? This definition ( from "Car Audio Terms defined") "Parametric EQ An equalizer with adjustable frequency, level and "Q"1" is not clear to me.. And there is no definition of graphic EQ , Thanks, Ted O. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I would read about them on BCAE1.com
Basically Graphic effects an "exact", or narrower frequency, and Parametric has kind of a pyramid effect on a wider, or narrower (whatever you chose. ie Q)range of frequencies. Best I can explain. I would just go to that site and read up. At least that is kind of how I understand it.
Houndog101
Houndog101
Fallston, Md.
Houndog101
