Diesel Audio AMP Help!
puffnpuff
10
Fl
Hi im supposed to be getting this amp:
Diesel Audio NSH-2.1400 - 2-Channel 2800Watts Mosfet Bridgeable Car Audio Amplifier
link: http://techronics.com/index.cfm?fuseaction=product.display&product_id=9117&aff=72182
Question: Is this amp one ohm stable? If not.... is it possible to run the following regardless of that?
- I would like it to run 4 Kicker CVR12 Car Audio COMP CVR 12" Round Subwooofer Dual 2 Ohm
Is this able to be done? Your prompt reasponse is greatly appericated !
Wire it like this. You can do better for the money though, no way I would spend that much money on that amp.
not trying to be mean but if you dont know then i trust you dont know what this kind of power can do to your car or truck.
for example:
-blow alternator from voltage drop
-blow amp for voltage drop
-blow subs from being over powered
thats just a few but if you dont know about these things and your just a guy with alot of money then i would just go to a audio store intown and have them do everything for you.
if you want to ignore everything i just said then i would suggest that you get the second one.
hey im just trying to see what would be the best for the money.
Your saying that the diesel audio 3000 watt mono amp has too much power for those subs? I was told the diesel dont put out nearly that much power.
they can for sure! like maybe 500 a peice.
but there peak being at 800 each i would not give each of them 750watts.... you know? they would last like a day or two.
i would go with a: hifonics Brutus bxi1608d. it will be perfect for those subs.... and less moneys
no TOTAL. And their website sucks, almost no specs, doesnt say what power at what impedance, I wouldnt buy their amps. Pick a different amp. On a budget I would pick up a Hifonics Brutus amp or a Crunch Ground Pounder series.
puffnpuff
puffnpuff
Fl
jdawg
