did the big 3, now I have problems with my system.
Wow that's strange. You said it worked before? Maybe the voltage regulator has blown and the amp is protecting itself. I don't think that's it though because you should see a battery or check engine light while it's running.
i think its just your amp now.
if your car is fully working perfectly and your amp is shutting on and off, it must be your amp.
check the voltage at the battery and then the amp. and make sure everything is getting a minimum of 12 volts. if everything is at 12. volts + then its probably your amp.
check the fuses on your amp too. i know mine would shut on and off a while ago. then it suddenly just shut off and i was tripping off it, checked the fuses on the amp and they were blown.
check your voltage on batt and amps, then check fuses on amp.
is your cars electrical running smooth?
What kind of amps and RCA's? My Sundown amp did this and found out it just didnt like the Stinger RCA's. I swapped RCA's and have no problems anymore....sounds goofy but it happens.
traksta15
I love lamp.
traksta15
Mcalester, Ok
Traks
