I'd just run it how ever you intended to in the first place. Not like you'll be losing a whole lot of money if it does die.I think it will last a little while. Plus i'm not gonna be pushing it seriously hard. Which box would make it last longer sealed or ported or would that matter?
Thats what i figured. :[It's not going to help unfortunately. Once the spider is stretched there is no going back
//content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gifIt's not going to help unfortunately. Once the spider is stretched there is no going back
this one read 3.5 , but the cheap meter reads .3 when i touch the leads together so i'm gonna say its about 3.2 ohms restnothing you can do its a spider problem recone is the only fix.on a soft spider shipping pushing on the surrond can damage it but if its a old sub i would say age did it.
did you touch the leads together and subtract the impedence from the dmm leads might be resting even lower. a normal dvc4 sub dosent rest perfectly at 4ohm per coil. most will be 3.5-4.0...
x2I'd go sealed. With an already loose suspension, it will bottom out easy ported
