Diamond M610
blowsoot
Well finally got it all hooked up M610 and KX600.1 amp. Birthsheet says 740. Anyways the sub doesn't seem like it gets that loud once you turn it up so high starts fartin not like a pop just kind of weird turn it down a lil sounds good but its not really loud. In a .70 sealed box. If the enclosure isn't air tight could that be the problem or am I just tripping. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I know when its sounds like shit to turn it down just saying pushing it higher it starts popin I turn it down (gains or SUB-W alpine deck) immediatly. Not even like a pop noise like its bottom out.
M610MKII DVC 4 wired parallel DMM says 2.1 ohm + - + neg - neg per coil. Then Im coming off 1 coil with a + and -
if its a D2 model,well you bought the wrong sub
since your amp makes 600w@2ohm you need a D4 sub....
your D6 is prolly only seeing 300 watt's from that amp since your not running at the right impidence
and 300w aint gonna move much sound
this is what you have
this is what you should have
My alpine deck is like SUB-W +7 bass boost on KX all the way down gain on amp 1/2 way up. Sounds good I think with a 45hz test tone it seems like. My rear speakers powered off my deck you can hear over the bass it seems like on rock. Those diamonds sub don't get loud at all or what? amp birthsheet claims 740
Can't really tell if there is a leak. Loosen the screws on the sub you can hear air chief out where it mounts.... screwed down its fine. Maybe my ears are that trashed these days. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif My IDQ 12 hit harder than this with 300watts heh.
blowsoot
blowsoot
Los Angeles, CA
blowsoot
michigan born
    May 14, 2026
michigan born
    May 14, 2026
