Diamond D5 1200.1
sotelomichael
Pharr, Tx.
Diamond D5 1200.1
Used, scratches on heat sink. Works great, guts look brand spanking new.
Monoblock Car Amplifier
1200 Watts RMS x 1 Channel @ 1 Ohm
Power / Protect LEDs
Adjustable Low Pass Filter
Adjustable Subsonic Filter
0° / 180° Phase Switch
Adjustable Input Sensitivity (Up to 5V RMS)
Strappable
Optional Wired Remote Gain Control (Not Included)
Massive Proprietary Heatsink
Nickel Plated Solid Brass Circuit Board Mounted Power / Speaker Connectors
Fly Cut Billet Aluminum End Plates
Fully Adjustable Mounting Feet
Fully Regulated Power Supply
2 oz. Copper Circuit Board
Dimensions: 11-1/2" L x 11-13/16" W x 3-13/16" H
175 shipped
Ups ground insured and well packaged
My bad,i read it on wooers ect and sonics
I was looking at it and wanted 1 ohm stable
Guess they had it wrong....it would have saved me $250 i just spent
Sorry about that...
Don't know ratings on 2 or 4 ohm. Pics sent. If the amp is 1200 RMS at 1ohm half of that is roughly 600 @ 2 ohm and half of that 300 at 4 ohm. It is usually the way amps produce power. I didn't pull that from the manual simply past experiences with different amps.
1200 RMS at 1 ohm. Clean professional reference grade power here guys. It's a steal. I remember not long ago people including myself were selling kicker zx 1000.1 for 200 shipped. No comparison. The diamond amp is superior
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
It should be fine as long as you're not looking to upgrade in the future.
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
sotelomichael
sotelomichael
Pharr, Tx.
aztec
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
